MyTvOnline +
Jprego
Message 19 of 19
Hi...
I got a Formuler 11 and I use MyTvonline + to see some uk channels and where I got YouTube Disney, Netflix etc...
Since my last update I just got the message Please check your internet connection (1) network error...
Is my IP address banned/blocked
or locked...
Can't have access to does anymore
Thank you
18 REPLIES 18
Message 1 of 19
OK thanks for confirming.
Message 2 of 19
Hi Karl thanks very much but there was a friend of mine I have sent the box and he manage to sorted out...was something related with the box specs, so he told me...
Everything is working now...cheers
Message 3 of 19
TalkTalk are not specifically blocking any legitimate IPTV Streams, and will only block any streams that have been identified as illegal or banned by issue of a court order.
Do you have access to another router for testing or would you like to swap out the current router to see if it is at fault.
Message 4 of 19
I have installed yesterday on mobile and it work's on mobile but on my mobile contract Tescos...
Message 5 of 19
Do you have the mytvonline+ app installed on an android device, and does this work when connected over Wi-Fi ?
Message 6 of 19
No I don't have VPN at all...
Message 7 of 19
Ah, maybe it is geo blocking. Are you accessing Disney+, Netflix etc. via a VPN?
Message 8 of 19
I've already did it...nothing shows up...trying cable on Lan 3 to tv and it's working...
I believe they think I got iptv and they blocked the lines...
I got Freeview and satellite for Portugal TV in another box, but not on Internet...a friend of mine told me it's possible that...
Message 9 of 19
Right, so you have two devices connected by ethernet to the router, but only one LAN port is showing as up? Maybe worth checking all the connections, swapping the cable around, trying different ports on the router etc.
Message 10 of 19
Got the box Formuler 11 and the
Tv...
Message 11 of 19
Have you actually got devices connected to each of the LAN ports? Which make/model of router do you have? It could be that which has failed.
Message 12 of 19
Ethernet...
I've been doing everything Talk Talk asking to do it...Reset, change this, change that etc...
In reality looks like they blocked or locked me...must call them tomorrow to see what's going on...because I have been using this boxes 6 years now and never had issues... I just don't understand why the Interface Status says i got 3 LAN's Down...thanks
Message 13 of 19
OK, are you connecting the box via ethernet, or wireless? Have you tried switching the router off for a full 30 minutes before restarting to reset the session?
Message 14 of 19
Well I open my router settings and the Interface Status says i got ...
ADSL WAN - Up
LAN 1 - Down
LAN 2 - Down
LAN 3 - Down
LAN 4 - Up
WLAN - Active
Message 15 of 19
No, still saying Please check your internet connection (1) a network error has occurred...
Message 16 of 19
And is it all working now?
Message 17 of 19
I got the box connected to the router...
Message 18 of 19
Are you sure it's not just failing to connect to the router? Have you checked the network settings?
