Netflix doesn't show all UK content (using unblocker or proxy?)
cj1980
Message 7 of 7
Netflix UK account won't find "better call Saul" when connected to TalkTalk WiFi, but finds it on my phone's 4G connection? Then find it on 4G and switch WiFi backon, I get a playback error about a using an unblocker or proxy. I don't have a VPN or anything like that switched on.
So on WiFi I can see Netflix content which plays fine, but it won't find better call Saul at all, and when I do find it using 4G and it plays, but the moment I then switch WiFi back on my phone, Netflix won't play as it thinks I'm using an unblocker or proxy. This is obviously something in TalkTalk settings in servers or the eero router. Please help!
6 REPLIES 6
Message 1 of 7
I don't know specifically what caused the problem but switching the router off for 30 minutes forces the start of a new internet session so it's possible that something changed but the change didn't take effect until you switched the router off for 30 minutes forcing the start of a new session
cj1980
Message 2 of 7
Hi Michelle
Yes have done that now,.seems to have fixed the issue. Do you know what caused it, that restarting the router would have fixed? Is this something I will need to do often?
Message 3 of 7
Did you also try the 30 minute router power down?
Message 4 of 7
Sony bravia android TV and pixel android smart phone. Same thing happens on both.
Message 5 of 7
Have you also tried powering down the router for a full 30 minutes and then retested again as this will reset the current session?
Message 6 of 7
What device(s) are you using?
