Network device disconnects from wifi
Rich57
Message 6 of 6
One of my network devices has disconnected from WiFi four times this year. I reconnect it using WPS but this involves climbing into the loft, which is rather inconvenient. To improve the connection I tried putting a WiFi extender in the loft, which is connected through the mains to a device close to the WiFi Hub. This has improved the signal level a little but the disconnection continues. The last incident was 3am today. Is there any investigation I can do at the Wi-Fi Hub?
Richard
Firefox
Win11 Home
TB
5 REPLIES 5
Message 1 of 6
Hi @Rich57
No problem for the delayed reply. It is probably worth checking for WiFi interference near the device(s) that drop out. I still need to know the make/model of router & extender that you have.
Rich57
Message 2 of 6
To answer your remaining questions, there is no inter-floor insulation but the loft insulation is foil-topped. There are no water tanks since the HP was installed. The solar inverter is steel-cased and 6m from the wifi extender. The HP control system is centrally-located and 2m from the wifi extender in line-of-sight. The solar inverter's wifi connection is rock solid; the only time I needed to reset it is when I changed router. The HP wifi interface loses its connection after a few days.
Sorry for this late reply - I have been unwell.
Richard
Firefox
Win11 Home
TB
Message 3 of 6
Hi @Rich57
You will always have problems then, because the foil on the insulation reflects most, if not all WiFi signals away from it, depending on how the WiFi extender connects back to the router. Which make/model of WiFi hub & extender do you have?
Rich57
Message 4 of 6
 Hi @KeithFrench . This device is a WiFi interface to heat pump control system manufactured by Mitsubishi (details attached).
My router is located close to the cable entry on the ground floor. The device is one of two in the loft of a two-storey detached house, the other being a solar inverter. The loft insulation has a metal foil covering and the HP control system is encased in a steel box. The WiFi interface is external to the steel box and only 2 m away from a WiFi extender. The inverter's WiFi interface doesn't have this problem.
Thanks for offering to help.
Richard
Firefox
Win11 Home
TB
Message 5 of 6
Hi @Rich57
Disconnecting from any WiFi network, should not result in a new WPS connection.
All WPS does is after providing a simple way to connect the device initially, it tells the device the router's wireless network name & password, plus depending on what the device is, might clone a few other WiFi parameters as well. When the device subsequently reconnects to the WiFi network, it does so via the normal wireless connection method as it now knows the network name & password.
To enable me to help you, I need to know:-
  1. The make/model of this device.
  2. Where is the router situated within the property and what electronic equipment is nearby, plus are there any large metal objects, glass or water tanks between it & this device? What inter-floor and or loft insulation do you have? Is any of this the type that is encased in a metal foil covering?
