Network unstable
cymro
Chat Champion
Message 35 of 35
Hi I got wireless security cameras I've had nearly 12 months ran no problems .now I keep getting message network unstable .I have put WiFi to diff channels trying to eliminate error .l have to reboot app also ive reset router .I rang talk talk. A tech.agent fiddled around now it's worse.. any one got any ideas ?
34 REPLIES 34
Message 1 of 35
OK, have a great Christmas 🙂
cymro
Chat Champion
Message 2 of 35
Hiya camera approx 30 foot from router earlier new router failed lost network settings Alexa stopped and fire stick I tried other router that was delivered this working fine
Yesterday as I said -75rssi today new router camera  -49rssi up to now no network error messages I'll monitor next few days I'll return two routers as agreed with Debbie thanks for help have good Xmas
Message 3 of 35
OK thanks. I think the rssi is a measure of wireless signal strength. Approximately how far away from the router are your cameras?
cymro
Chat Champion
Message 4 of 35
Hi just been on chat to camera tech
They said this  I am getting _75 rssi
This is cause of unstable network
They say this Yes -75 rssi is cause  here's the range:
(-40~-50dBm:good /-70~-80dBm:weak/ >-90dBm: Very poor
Any way altering rssi? Thanks
Message 5 of 35
Hi cymro,
Did you get any information with the camera's that explains exactly what 'network unstable' means or what could be causing it?
cymro
Chat Champion
Message 6 of 35
Hi used new cables .socket has inbuilt filter this was checked openreach  couple  months ago
Router hard wired to TV noticed same can't connect .on speed test and intermittent won't load say you tube
In past they found probs exchange we were having slow internet few months ago .one engineer was on about replacing house line as intermittent fault .also Debbie just check my settings talk talk tech have been fiddling about before I contacted you thanks
Message 7 of 35
Hi cymro
Is it only the wireless connection dropping?
Is the new router at the test socket? When you connected the router did you use the new cables and filter?
cymro
Chat Champion
Message 8 of 35
Hi Debbie both routers received Friday same delivery set up new router monitored over weekend still had a couple network unstable messages also tried run TT speed test same time had can not connect server error any ideas thanks .
Message 9 of 35
Hi cymro
No problem 🙂
Thanks again.
cymro
Chat Champion
Message 10 of 35
Thanks Debbie appreciated
Message 11 of 35
Hi cymro
I have ordered another router. If the first router arrives then please can you return one of the routers using the returns bag.
Thanks again.
cymro
Chat Champion
Message 12 of 35
Hi just checked yodel website now getting this
Parcel status
Your parcel has arrived at your local depot
Estimated delivery date:
Unavailable at this time
Obviously not getting today  can u resend today then hopefully get for weekend thanks
Message 13 of 35
Hi cymro
Apologies for this. I've had similar issues myself with a different courier and deliveries.
If you've not received this by Wednesday, then I will need to send another router.
cymro
Chat Champion
Message 14 of 35
Hi just looked yodel tracking
My Parcel's Journey
02/12/22
02:30
Been there 3 days  not impressed at all can u chase it up not even booked out for delivery
Message 15 of 35
Hi cymro
Apologies for this.
The router is showing as dispatched on 01/12. If you haven't received this by Wednesday, then please let me know.
cymro
Chat Champion
Message 16 of 35
Hiya nothings turned up Debbie
Maybe stuck in Xmas post 😔
Message 17 of 35
Message 18 of 35
Hi cymro
Apologies, yes the router has been ordered.
You should receive this within the next 24-48hrs.
cymro
Chat Champion
Message 19 of 35
Hi did you send a router? Thanks
Message 20 of 35
Hi cymro
No problem. Please can you add your name to your Community Profile, I can then send the replacement router.
