on 12-12-2022 11:41 AM
Since I got the Sagemcom router from TT, I've not been able to connect to my work VPN unless I put the laptop concerned into the DMZ. Obviously this isn't ideal, so I've gone back to using the old router - Huawei HG633 - which works fine. I think I gather from reading other posts that there's a firmware update to fix the Sagemcom? If so, can I have it, please?
Cheers
Mike
on 13-12-2022 12:12 PM
Hi Mike,
How is it going, has the firmware update resolved the problem?
on 13-12-2022 07:26 AM
Firmware update has started and should complete within 10 minutes
on 13-12-2022 07:25 AM
Morning Mike,
I'm going to start the firmware update now, please don't switch off your router
on 12-12-2022 12:27 PM
No, that's fine, I can see them in your Community Profile
on 12-12-2022 12:23 PM
Hi Chris,
Fair enough. I'll connect it last thing tonight then.
Do you need my address/phone number?
Thanks,
Mike
on 12-12-2022 12:17 PM
I'll try to do the update between 7 to 7:30. I'm sorry, the firmware update has to be done remotely, we can't send it out as a file
on 12-12-2022 12:14 PM
Hi Chris,
That'd be fine as long as it was done 9am.
Alternatively, would you trust me to do the update myself? I've done router updates before, and I guess you could email me the firmware?
Cheers
Mike
on 12-12-2022 12:09 PM
Hi Mike,
Yes that the actual firmware version. We can do the firmware update tomorrow morning after 7am if that's OK
on 12-12-2022 11:55 AM
Hi Debbie,
Thanks for the quick reply. Can I connect it after work today - say at 5pm? Got a lot on today!
It says it's running 'software version SG4K100136'. Is that actually the firmware in reality?
Cheers
Mike
on 12-12-2022 11:44 AM
Hi Mike
If you connect your Sagemcom router to the line then we can check your firmware version and make the necessary changes.
