New build enquiry
Self-builder-John
Message 5 of 5
I'm building a self-build home next year in Suffolk and need some advice on getting the broadband cable from the overhead pole into my house. Can you let me know how I can contact a Talk Talk engineer so we can talk about it?
4 REPLIES 4
Message 1 of 5
Hi John,
No we don't install the cable, as ferguson has said, you'll need to contact Openreach directly.
Message 2 of 5
You will need to contact Openreach directly.
Self-builder-John
Message 3 of 5
Michelle,
Thanks for the reply. Just to double-check, you're saying Talk Talk don't install the cable from the street to my house via a duct I will install under the drive? If that is the case, do I need to talk to someone like BT or Open Reach?
Thanks,
John
Message 4 of 5
Hi John,
If you're building a new build property you would need to arrange for it to be added to the Royal Mail database. Only then would you be able to place an order for a broadband connection. We don't lay the infrastructure ourselves so we wouldn't be able to set this up for you.
