Opening UDP 6000 on HG633- help?
johnbergerrack
Message 5 of 5
Thought to ask here, I feel like I've tried everything I need to. If there's any context you need me to add, by all means ask.
Here are the settings I'm using for what I think should open up UDP 6000 on my HG633 router.
I created a port mapping rule with the following settings- please see screenshot:
The internal host is my computer name, which is confirmed by looking at the active devices list, then checking my  PC's device name under 'Properties' of my computer.
4 REPLIES 4
Message 1 of 5
Hi @johnbergerrack
That is exactly what I wanted, thank-you. How do you know it is not working, please can you telling your testing procedure. You will not be able to use a port checking website, as they are only compatible with TCP ports, not UDP ones.
Message 2 of 5
I am not sure what you mean, this is all I have under port mapping. The "application" titled "GT4online" is the screenshot in the first post.
Message 3 of 5
Hi @johnbergerrack
That screenshot is only half of the config, please can you send a screenshot of the port mapping rule as well? Thanks.
Message 4 of 5
@KeithFrench - Is this something that you can provide advice on please?
