Out of date firmware FAST 5364?
fre55die
Message 22 of 22
Hi  @Chris-TalkTalk
My Sagemcom FAST 5364 is still running SG4K100124 firmware. If this is old could you  update it for me please? Whenever I do a self service check it tells me that it's out of date.
Thanks a lot in advance.
21 REPLIES 21
Divsec
Message 21 of 22
Hi @fre55die hope you are well. Your post has been escalated to a higher place and might not get actioned until Tuesday.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
