29-04-2022 05:25 PM - edited 01-05-2022 04:28 PM
My Sagemcom FAST 5364 is still running SG4K100124 firmware. If this is old could you update it for me please? Whenever I do a self service check it tells me that it's out of date.
Thanks a lot in advance.
on 19-05-2022 12:22 PM
Very strange because I was getting higher speeds before the new router. My Speedtest results show that it dropped from 39.7Mbps to 36.64Mbps when I swapped router over and that's not to the router.
Oh well, if there's nothing showing up I suppose that I shall live with it.
on 19-05-2022 11:37 AM
Estimated speed for your line is 35-38mb, so realistically I do not see this achieving more than 40ish on a good day. All tests are clear, all levels look fine and profile settings are correct.
on 19-05-2022 11:06 AM
Thanks for that. I've tried a 50 minute power off but, no speed increase. I'm supposed to be on fibre 65. Openreach installed fibre to the street a few months ago.
on 16-05-2022 02:49 PM
Profile is correctly set, but sync is at 38.8mb. You could try a 30 minute powerdown to see if it picks up a little. As to the firmware sync rate should remain the same, but there was an issue with an earlier firmware affecting overall upload speeds when downloading. but nothing we know of affecting sync speeds.
Also, don't worry about return charges etc, we know you guys have a lot of equipment to test from time to time, so we would remove any such charge if it appear, if you ever see this, just flag to one of the team and we'll take care of it.
16-05-2022 02:29 PM - edited 16-05-2022 02:34 PM
Thanks @Karl-TalkTalk
I was just starting to get a bit worried about the time frame due to the demands being made and £50 charges being imposed by TT for late returns as pointed out by @Gliwmaeden2.
I have noticed that this one on SG4K100136 is slower than the last one with my speeds having dropped from 41Mbps to 36Mbps. Any thoughts?
on 16-05-2022 10:15 AM
i'll send another, although the first has not dispatched yet, there is a note saying it is in the process of being dispatched.
on 16-05-2022 09:59 AM
Todays post has arrived and I still haven't received the returns bag or labels. Could you send me another set please as it looks like the ones that you sent have gone AWOL.
on 09-05-2022 07:47 AM
Hi fre55die
Returns bag on the way.
on 07-05-2022 04:44 PM
New router arrived thank you. There is no returns label or bag. Could you please send these out to me.
on 03-05-2022 12:12 PM
usually on time 🙂
on 03-05-2022 12:05 PM
O.K. thats fine with me. How are the dispatches going these days timewise?
on 03-05-2022 11:51 AM
I'd just leave it for now.
on 03-05-2022 11:32 AM
@Karl-TalkTalk I was not using the PC at the time and not watching any of the IPTV channels. Anything that you want me to do until putting the old box back on to pin reset later ? or just leave it?
on 03-05-2022 11:03 AM
It does sound like the update did not go as planned 😞
on 03-05-2022 11:01 AM
@Karl-TalkTalk Thanks for that. I'll try the pin reset later on today. For your info it also does not show the actual F/W version any more it is blank after "version" so it does sound as if it may be bricked.
on 03-05-2022 10:53 AM
Hi fre55die
If the update has caused an issue with the router, you can try a pin reset, but to be on the safe side I'll get a hub out to you asap.
on 03-05-2022 10:46 AM
@Karl-TalkTalk The upgrade has caused a problem and have had to swap out the router to write this.
It starts up then the orange light comes on then solid white for about 3 minutes then internet is lost and orange light sequence comes on again and this continues continuously. I left it for about 45mins and it was still doing it. I then turned it off and unplugged it for about 15 mins. I tried again and it is still doing it.
HELP any ideas? As I said I have put the trial 5464 on temporarily, however I know that the wi-fi on this one is pretty poor so I need a fix for my standard 5364 or a replacement ASAP.
Could I have your advice urgently please.
on 03-05-2022 09:03 AM
Hi fre55die,
your router should now be running v136 firmware.
02-05-2022 04:44 PM - edited 02-05-2022 05:23 PM
Anytime is fine, the router is permanently on.
T
on 02-05-2022 10:12 AM
Hi fre55die
When would be the best time to update the firmware?
We advise to leave the router switched on without being rebooted whilst we update the FW.
