P2P filtering and limitations
nikomnht
Message 2 of 2
I know that Talktalk has a speed cap on startup and P2P filters and other limits. This is not fair because it limits the speed of our internet.
Have any of you had a similar problem and were you able to remove the locks via Talktalk?
how do i know?
By downloading various applications via VPN, my speeds are 3 and 4 times higher than by just a Talktalk connection. What gray about filtering our connections.
I can use VPN endlessly, but that's not why I set up 65mb internet to only have 10mb.
Nikodem Adamiak
1 REPLY 1
Chris-TalkTalk
Message 1 of 2
Hi nikomnht,
I've replied on your other thread. Please just stick to the one thread to avoid confusion
