POOR WIFI
miterkint
Message 3 of 3
hi,
I feel like my wifi has been pretty poor for a while now. It mainly seems to be the 2.4 ghz channel. If i try to play online with my PS4 its basically unusable, Ive had to resort to using a powerline adapter. The router is ten years old now could it be on the way out? Any suggestions on something I could try to improve things?
thanks
Message 1 of 3
Hi miterkint
Please can you update your Community Profile to include your name and TalkTalk landline number, we can then look into this further.
Message 2 of 3
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
