Poor Broadband and keeps dropping out?
gphelps5
Message 4 of 4
Hi have had a very good TalkTalk connection over the past few years but in the last week or so the sevice has degraded with the connection going very slow and even dropping?
I have not changed anything with my home setup (router etc) for years, so it is not a hardware issue and when I try to check this on the TalkTalk site, although some of the test come back 'All working',  with other I get things like this
Please can you re-store my connection back to what it was.
Thank you
3 REPLIES 3
Message 1 of 4
Thanks for the update and please let us know if you need any assistance 🙂
gphelps5
Message 2 of 4
It's funny  because after a week or so of bad service, I tell you about it and it's fixed.
Thank you for whatever you did. If it goes weak again, I may try the router 🙂
Message 3 of 4
Hi gphelps5
The line test hasn't detected any faults. The line is in sync at 76.5mb and the connection appears to be stable.
Would you like me to send a replacement router for testing so we can rule this out?
