on 28-08-2023 03:22 PM
I'm trying to set up port forwarding to my home server and struggling.
DNS is all working fine - pinging the domain gets rerouted to the router
I have set up port forwarding on the router to direct it to the (reserved) ip of the server
However nothing gets through to the server itself, and when using portchecker.co both 80 and 443 are reported as being closed. Is there something else I should be doing to get this working?
on 29-08-2023 10:27 PM
Yeah it seems like I was running into a pair of issues simultaneously
Activating proxy on cloudflare bypasses the NAT loopback problem, but seems to have some of the rate limiting issues I was having with the tunnels earlier. Guess I need to get a new router if the TT one won't support it natively
29-08-2023 10:10 PM - edited 29-08-2023 10:12 PM
I've made and repeated many mistakes over and over when setting up webservers. The 2 most common I've made is not having the server up and running when doing a port check. The second is forgetting about NAT Loopback. After that is not opening the ports on the server and the firewall. As @KeithFrench has said - as long as it's working...
on 29-08-2023 10:06 PM
Well, I was just going on what you said originally. Still, if it is working now, that's great.
on 29-08-2023 10:04 PM
Hmmm wierdness ensues. Wireshark showed nothing getting through at all on 80 and 443
I restarted the router and now portchecker.co now lists both 80 and 443 as open
This makes me think @Piethorne might be right in it being NAT loopback, I hadn't considered it because of the original port issue
on 29-08-2023 09:46 PM
No, it is not that @Piethorne the OP says:-
"when using portchecker.co both 80 and 443 are reported as being closed."
on 29-08-2023 09:41 PM
NAT Loopback ?
on 29-08-2023 11:25 AM
The router works fine forwarding these ports, I have rechecked it this morning. I can analyse any Wireshark traces if required.
on 29-08-2023 11:14 AM
I haven't found anything that would suggest that and many others are able to do what I'm trying using the OS, their support suggested I checked with my ISP - that said I can look into it a bit deeper this evening when I get home from work and double check with them. Should be able to stick Wireshark on it and see if anything gets through.
I have had some success previously using Cloudflare "tunnels" which seem to be akin to a vpn between the NAS and cloudflare, unfotunately they are rate limited which made the usability a bit suspect, and acting like a vpn might be bypassing your suggested blocking.
Will update you when I get a chance to do some testing, if you have any other ideas I can check please let me know! 🙂
on 29-08-2023 10:53 AM
Thanks for that @charliepaterson.
I think that the NAS is blocking access to connections coming into it from any other IP network, apart from its local network of 192.168.1.0, by default. Is there anything in the NAS documentation and or support website to confirm or deny this? If it is disabled by default, you will need to find out how to enable access from other networks.
It is easy to find out if TCP ports 80 & 443 are open, but the NAS would appear to be going a stage further by checking the IP packet's source IP address as well. If you can install Wireshark on the Linux part, that would prove it.
on 29-08-2023 09:00 AM
The NAS is a self contained unit, I do have access to it (it's in the attic) and the web ui is pretty comprehensive in terms of things I can change - and includes a shell terminal for fiddling with the linux based OS directly.
It runs "apps" including Jellyfin/Plex which are what I'm more interested in accessing remotely than the web UI itself - it has an internal reverse proxy so if mydomain.com points to the server itself, jellyfin.mydomain.com will be rerouted to the jellyfin app and let me stream my movies outside of the house. Similarly with HomeAssistant so I can check my dashboard remotely, host a vpn so I can play LAN games with friends, stuff like that
on 29-08-2023 08:39 AM
Thanks for that, it is all OK. I think I know what the problem is, but I want to make sure I understand what you want to do.
Is this NAS a self contained unit, running it's own operating system, which you have no direct access to? You can only change certain things within its browser interface & it is this that you want to access remotely?
on 28-08-2023 06:13 PM
Thanks for helping
on 28-08-2023 06:01 PM
What are the following set to on the network card of the NAS:-
on 28-08-2023 04:18 PM
It's running TrueNAS Scale - no additional firewalls as far as I can tell
It has a static IP of 192.168.1.38 - and I can access the web UI on that ip address just fine from within the LAN
on 28-08-2023 03:50 PM
There is nothing wrong with your rules. What sort of device is hosting your server? Does it have its own firewall (do not touch the router's firewall)? If so, have you allowed the two ports through that firewall? Is your web server bound to this 192.168.1.38?
