on 17-04-2025 06:59 PM
Hi, my iPad has a privacy warning showing in wi-if which says THIS NETWORK IS BLOCKING ENCRYPTED DNS TRAFFIC, how do I fix this as it is affecting some websites I try to go into.
many thanks
on 17-04-2025 07:58 PM
Ah, no worries, sorry we couldn't get there.
on 17-04-2025 07:56 PM
Ok no problem, thanks for all your help.
on 17-04-2025 07:55 PM
OK my friend, well that's me all out I'm afraid. Reach out to Apple directly, perhaps?
on 17-04-2025 07:53 PM
Done a full factory reset this morning hoping that would work but it didn’t
on 17-04-2025 07:51 PM
Right. Does the offending iPad have the latest iPadOS on board? Maybe try a hard reset?
on 17-04-2025 07:49 PM
The thing is we have another iPad and two iPhones with the same settings and they work fine. It’s just baffling.
on 17-04-2025 07:47 PM
Are you using TalkTalk DNS server settings in your router? Maybe change those to third-party e.g. Google DNS.
on 17-04-2025 07:44 PM
Yes they are the same, many thanks for your help. Hopefully someone else will come up with something else.
on 17-04-2025 07:39 PM
Hmm. And have you checked that the DNS settings actually match the server settings? I'm running out of ideas here tbh.
on 17-04-2025 07:36 PM
Set to fixed.
on 17-04-2025 07:34 PM
OK, one more thing: again under WiFi settings, is your Private WiFi address set to Fixed, or otherwise?
on 17-04-2025 07:27 PM
Yes it is
on 17-04-2025 07:22 PM
OK, check that Configure DNS is set to Automatic in WiFi settings.
on 17-04-2025 07:15 PM
Private relay is showing off
on 17-04-2025 07:08 PM
Try switching off Private Relay in your iPad settings.
