Put router into bridge/modem mode
Craig01988
Message 4 of 4
I'm looking to find a way of using a third part router.
I was hoping to be able to out my current router into bridge or modem mode?
Any help appreciated
Craig
3 REPLIES 3
Craig01988
Message 1 of 4
Thanks for the replies. I want to use a seperate rotuer because of the number of devices I have and teh advanced features offered by the netgear router I was looking at. This router isnt available with built in ADSL/VDSL.
martswain
Message 2 of 4
@Craig01988 no TT routers or Hubs can be put into modem-only mode.
"Firmware says no"
Message 3 of 4
If you want to use a third-party router with built-in ADSL/VDSL modem then you can connect it to your broadband socket directly. If you just want a separate router, then I would ask "why?"
