on 04-12-2024 10:27 AM
Hi, I have previously reported a fault with my router. I spent a full day speaking to agents who requested I run the same tests over and over - they could not find a fault.
Today my internet has dropped again, and the online diagnostic tool came to the same conclusion. I received the message that there may be an issue with my setup after running this test.
Please can I request a new router ? I have tested an old one in the house from previous tenants, and can gain connection, so assuming it’s a fault with my own router.
Thank you!
on 09-12-2024 06:53 AM
on 07-12-2024 11:43 AM
Thank you !
Received and all connected, thanks again 🙂
on 05-12-2024 07:44 AM
Hi @mfc4638
Thank you 🙂
Let us know how you get on.
Thanks again.
on 05-12-2024 07:05 AM
Hi Debbie,
Thanks so much ! I’ve done this now
on 05-12-2024 06:35 AM
Hi @mfc4638
Apologies for this.
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send you a replacement router.
