Replacement Router Request
Aaron1974
Message 5 of 5
Can I have a new Router sent please.  I replaced my old router with an Asus one about 5 years ago and having had line problems the Engineer who visited to check our lines believe it is the router.  Whilst they had reset the speed on the line and it was stable for a couple of days, download speed has now dropped 20Mbps.
Many thanks
4 REPLIES 4
Message 1 of 5
Hi there @Aaron1974 you have 2 threads, I will close this thread as duplicate. Please check on the other thread @ferguson has asked if you have a full fibre connection?
Phili
Message 2 of 5
OK, but do you have one that you can try just for testing purposes? The support team are unlikely to be able to help with a third-party router.
Aaron1974
Message 3 of 5
I have 2 older Talktalk routers.  The last one was playing up a bit and I bought a higher spec one about 5 years ago.
Message 4 of 5
Do you not have a TalkTalk router at all? If not, what happened to it?
