Router Query
k3572
Message 7 of 7
Hi, i had a problem  yesterday lost my  internet service had the  constant Flashing orange , its going again  fine now  after taking the cable out refitting etc and rebooting the Router it came back solid white, loose connection i think,
my query is regarding the my router dashboard, i went in to put a stronger password than the default for my wifi network but was a bit puzzled that under the  "Internet connection box"  it says Status- Disconnected- your router is not currently connected to the internet, although my internet is working fine ,  i did a Connection test result came back  fault has been fixed, hope this make sense just wondered why this is.
thanks
6 REPLIES 6
Message 1 of 7
Hi Kevin,
You could try switching the router off for 30 minutes, then switch back on and retest (but personally if it's working OK I wouldn't bother)
k3572
Message 2 of 7
hi Debbie
there are no issue's when i run the connection test apart from the "your broadband isn't keep up with you" prompt
i had a go at disconnecting and reconnecting the cable to the router (sagecom fast 5364) but that  has made no difference  still says Status disconnected although my broadband is working fine.
cheers
kevin
Message 3 of 7
Hi Kevin
Just checking in to see how the connection has been since your last post?
If you run a test using My Connection, does it show any issues?
Message 4 of 7
hi chris sorry about delay in replying
My Internet service is still fine no problems with it ,  just logged into to the router  wi fi hub again , still showing under the  #internet connection#  header - Status disconnected-  (your router is not currently connected to the internet), under the  #my wifi#  title it obviously says enabled  and under #my devices# it shows my 1 device a computer fine ,  the computer is upstairs from the router and main socket, so there is no ethernet cable between them i wondered if that what it was referring to though that seems a bid odd.
thanks for your reply
kevin
Chris-TalkTalk
Message 5 of 7
Hi k3572,
How are you getting on, if you still need assistance please let us know
Message 6 of 7
It can take a while for that display to update.
