3 hours ago
Hi, I believe I’ve got an issue with my router - DG8041W-2.T5
The router loses connection, flashes white/orange for a minute, then reconnects.
This happens multiple times per day, and has got more frequent over the last few weeks.
I’ve already tried a factory reset, no change. Have run line tests etc with no issue. The router always reconnects successfully.
I suspect the router is faulty. Is it possible to get a replacement sent out?
Thanks,
Andrew
56 minutes ago
Thanks for your help Keith, glad to have my suspicions on the router being faulty confirmed.
2 hours ago
This is due to a bug in firmware V1.05. This router is now discontinued & I have asked one of TalkTalk's support to pick your thread up and replace it for you.
