Router disconnecting / connection issues
zoecj
Message 21 of 21
Hello.  My router is regularly disconnecting.  My laptop advises I have no internet connection and when I check the router the light is flashing orange and white intermittently.  This is happening several times a day.
Even when my internet is showing as working, I am still experiencing connection issues.  My wifi shows as full strength and speed tests are coming back fine, but simple apps aren't working e.g. a teams video call will keep dropping out due to 'connection issues'.  I thought it may be because of where I was in the house, so have situated myself within three foot of the router with no obstructions, but still experience the same problems.
20 REPLIES 20
Message 1 of 21
Hi zoecj
I've completed a line test which hasn't detected any faults and your line is showing in sync and connected.
Are you still experiencing issues?
zoecj
Message 2 of 21
Morning
The new route arrived the next day. Thank you.
The constant disconnections seemed to stop but I’ve still been experiencing lots off buffering / poor network quality messages on both my laptop for video calls and when using our smart tv.
This morning however we have woken up with no internet. I’ve tried restarting and unplugging and re plugging everything. It’s flashes orange and eventually just turns to a solid orange.
Message 3 of 21
zoecj
Message 4 of 21
Ok, great!  Thanks so much.
Message 5 of 21
I'd test with the new router in the normal socket initially and then the test socket if the issue continues
zoecj
Message 6 of 21
Thank you!  Should I replace the cover on the test socket now, so I can plug straight into that?  Or is it best to use the microfilter and test socket?
Message 7 of 21
I've ordered the router, it should be with you within a couple of working days
zoecj
Message 8 of 21
Yes, that would be great, thank you.
Message 9 of 21
Would you like me to send another router to test with?
zoecj
Message 10 of 21
No, I only have the one router.
zoecj
Message 11 of 21
Message 12 of 21
Do you have another router that you can test with?
zoecj
Message 13 of 21
We do not have a house phone
Message 14 of 21
OK thanks, are you experiencing any problems with your telephone service, any noise on the line?
zoecj
Message 15 of 21
Hi.
We have two phones lines coming from the same telegraph pole coming into the house.  One goes upstairs where there is a BT open reach NTE 5C box.
The other enters the house downstairs into the socket I am using.
When we moved into the house last year we set up one phone line and number (with TalkTalk) which works via the socket downstairs.  there are no extensions to this socket.
Message 16 of 21
Thanks for the information. Do you have any extension sockets or is this the only telephone socket in your home?
zoecj
Message 17 of 21
Hi Chris.
It was plugged into a FTTC socket by the front door with the router plugged into the top port.
I have removed the front panel and used a microfilter to connect into the test port.
It does appears a few of the wires in the box are broken... See photo attached.  Is that normal?
Message 18 of 21
Hi zoecj,
I'm sorry to hear that you're experiencing problems with your service. Line test is passing but I can see that there have been some disconnections. Is your router currently connected to your test socket? - Your guide to main phone sockets - TalkTalk Help & Support
zoecj
Message 19 of 21
Ok, thank you.  I think I have complete the settings you have mentioned.
Gliwmaeden2
Message 20 of 21
@zoecj, please stick with this thread.  I've moved your duplicate topic out of the way.
You are in the queue for attention from staff.
They'll need to identify your account, so please complete your community forum profile details. You need to add your Talktalk landline number or Account number by going via your avatar/name; settings; launch profile wizard.
