Router failure, flashing amber
Jeremy63
Message 9 of 9
Anyone had issues after a Smart Meter installation. Router hub just flashes amber and is no longer visible to my devices. I've read that engineers who flick the mains switch rather than powering off the router can fry it. How do i go about gettung a replacement hub?
JemRichy63
8 REPLIES 8
Message 1 of 9
Hi Jeremy,
Glad to hear the new router has resolved the problem. Yes please return the faulty power adapter too
Jeremy63
Message 2 of 9
Just received the replacement router hub. Process of elimination, it was the power adaptor that was faulty.
I will return the router ASAP. Do you want me to include the faulty power adaptor or shall I bin it. Thank you for your swift attention.
JemRichy63
Message 3 of 9
Hi @Jeremy63
I've ordered the replacement router, please allow 24-48hrs for this to arrive.
Jeremy63
Message 4 of 9
No phone connected to this line. All worked okay b4 the Smart meter install.
JemRichy63
Message 5 of 9
Hi Jeremy,
Thank you. I've run a few tests on the line now just to rule out any potential line faults. One is clear and the other is inconclusive. Can I just ask, do you have a dial tone and is the voice service ok? If it is then I think we should send a replacement router for testing purposes to rule this out.
Jeremy63
Message 6 of 9
Yes. Power off, reset etc. All tried. Details updated.
JemRichy63
Message 7 of 9
Hi Jeremy,
I'm sorry to hear this. Have you tried factory resetting the router?
  • Name
  • Telephone number or Account number
  • Alternative contact number
Divsec
Message 8 of 9
Hi @Jeremy63 have you tried rebooting the router?
your post has been escalated and you should hear soon.  In the meantime please check your community profile and add your landline number and/or account number so your account can be identified. Please don't post personal information here.
