Router not working properly
Nora151
Message 8 of 8
An engineer came out to fix a fault with the line and when he had finished he said the Router i had was ancient and i should get it changed but when I spoke to an agent they said they would have to do some checks before they can change the router? Surely the engineer report said it needed changing? Anyway wifi is still cutting out internittently.
My router is: Huawei-HG633 if that helps?
7 REPLIES 7
Message 1 of 8
Hi Nora,
Glad to hear the new router is a bit better. If you need anything further from our Team, just ask.
Nora151
Message 2 of 8
My son in law installed it yesterday for me and the signal has been much better.  None of my devices have disconnected and have no signal low messages. Fingers crossed it will stay like that . Thanks for sending the router so quickly. Nora
Message 3 of 8
How are you getting on?
Message 4 of 8
Hi Nora
Thank you 🙂
I have ordered the router, please allow 24-48hrs for this to arrive.
Thanks again.
Nora151
Message 5 of 8
Thanks Debbie I have updated my profile and added the number.
Message 6 of 8
Hi Nora151
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send a replacement router.
Message 7 of 8
If you would like the support team here to look into this for you make sure that your personal details including TalkTalk phone number and/or account number are complete on your community profile (click here) so that they can link your forum identity with your account and then wait for them to respond.
