on 09-06-2025 06:35 PM
My ethernet connected router often reboots itself, when I start my computer.
This is the replacement router you sent to me in October 2023.
Everything works ok once it has booted up, but I'd still like to try and correct this.
Any assistance would be appreciated.
on 30-06-2025 11:06 AM
Thanks for letting us know, glad my suggestion proved to be the solution.
on 30-06-2025 10:56 AM
The replacement power adaptor seems to have resolved the issue.
Thanks for your help.
on 10-06-2025 09:05 AM
Just sent a PM, as requested.
on 10-06-2025 08:58 AM
Please send us your TalkTalk account number on private messages.
Kanya
on 10-06-2025 08:56 AM
There is no wireless card in this computer, but I have laptops which connect ok.
on 10-06-2025 08:54 AM
Okay that's perfect. Have you ever tried connecting your computer wirelessly?
Kanya
on 10-06-2025 08:53 AM
Yes to a yellow port, which is furthest away from the red one.
on 10-06-2025 08:49 AM
Okay, can you tell me where exactly is the ethernet cable connected to in the router is connected to the yellow goldish ports?
Kanya
on 10-06-2025 08:47 AM
Via an Ethernet cable approximately I metre long.
on 10-06-2025 08:43 AM
Oh, I see, May I ask. How is the computer connected to the router?
Kanya
on 10-06-2025 08:41 AM
Thanks Kanya.
After I switched the mains power on this morning to my computer, the router rebooted before I could turn the computer on. The router is on it's own power line.
I haven't changed the router power adaptor yet.
The computer should be on for the rest of the day.
on 10-06-2025 08:08 AM
Hey there, Dennisl. We will need to check this for you. Please advise when you are home and ready.
Kanya
on 09-06-2025 07:13 PM
Yes I have still the original Huawei power adaptor 151206-11.
I will give it a try in the morning.
on 09-06-2025 07:05 PM
Hi @dennisl your post has been escalated, I have an inkling this could be due to an underperforming power block, do you have a compatible spare to try?
