on 03-04-2023 02:44 PM
My Sagecom router suddenly stopped working - the powers supply had died. After lengthy chat last week I was sent a replacement - a Huawei power supply - wouldn't fit the back. Very annoying. Can a moderator on the forum arrange for a correct Sagecom power supply replacement. This is the one that died:
Sagecom powersupply needed
on 23-02-2024 12:05 PM
Hi @Poppy12345
Please can you create a new topic on the Community, we can then take a look at this for you.
on 23-02-2024 12:03 PM
I need help with router
on 23-02-2024 12:02 PM
@Poppy12345 wrote:New router dose not fit
on 04-04-2023 07:26 AM
Hi Fortesmentum
No problem. Please let us know if you do experience any further issues.
on 03-04-2023 05:14 PM
Hello and thank you both very much for looking after me with respect of this. That is most kind.
on 03-04-2023 03:37 PM
Hi Fortesmentum,
I've ordered a replacement router, it should be with you within a couple of days. I've also ordered a returns bag to send the old router back in
on 03-04-2023 02:50 PM
I always thought that they would not supply a replacement power supply, but replaced the whole router instead. I have asked one of TalkTalk's support to pick your thread up and sort it for you.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
