Slow/Intermittent Broadband
Richard_Whitney
Message 33 of 33
Normally we get a download speed of 2-3mbps via a wired connection, but for the last few days we’ve been dropping down to around 0.3mbps. Sometimes it’s gone off entirely. Speeds are from the test socket, with no other appliances connected and all sockets have filters. The landline is working fine.
The speed goes up again after a router reset, but only for a few hours. We’re in a pretty poor area in terms of infrastructure.
Would it be possible to reset the line again please? This has worked well in the past.
Thanks in advance,
Richard
32 REPLIES 32
Richard_Whitney
Message 21 of 33
Hi Michelle,
Not yet but I’ll plug that in when I get back and leave it for 24 hours again. Is it possible to get a new router if that seems to be the issue?
Thanks,
Richard
Message 22 of 33
Hi Richard,
Thanks for the update. I can still see re-connections on the line. Is the alternative router now connected to the test socket?
Message 23 of 33
Hi Chris,
Not expecting a reply till Monday obviously, but just to let you know that the speed’s stayed up but the signal’s dropped out a few times over the weekend. The router’s been plugged into the test socket since Friday night.
Does this tally up with what you’re seeing at your end?
Thanks,
Richard
Message 24 of 33
OK thanks, you too 🙂
Richard_Whitney
Message 25 of 33
Cheers Chris, I’ll do that when I get home. I might have the old router somewhere as well if we need to test that against the new one.
Have a good weekend.
Message 26 of 33
If possible could you leave the router connected to the test socket for at least 24 hours and we can check the line history on Monday to see how it's been
(it's possible that something has been disturbed but line test isn't picking up any faults)
Richard_Whitney
Message 27 of 33
I did try it in there last night with similar results, but I had to move it back downstairs before I left this morning. There’s been some Openreach guys working round the corner this week - is it possible something’s been disturbed?
Message 28 of 33
Thanks Richard, is your router currently connected to your test socket? - Your guide to main phone sockets - TalkTalk Help & Support
Message 29 of 33
Hi Divsec, thanks for that. We tried a long power down last night but then it was up to its usual tricks this morning.
Message 30 of 33
Hi Chris, we don’t use the landline much but it sounded ok when we tested it this morning. We’ve also reset the router a few times so that might be it. It’s just cutting out every now and again even when the speed’s up.
Thanks,
Richard
Divsec
Message 31 of 33
Hi @Richard_Whitney it looks as though @Chris-TalkTalk has scheduled a check back with you for today. You might try a 30 minute reboot ,power down router for 30 minutes then reboot. This often tricks DLM into short term improvements.
Chris-TalkTalk
Message 32 of 33
Hi Richard,
Your internet connection looks very unstable, are you experiencing any problems with your telephone service, any noise on the line?
