on 15-03-2023 02:25 PM
I am on 150 fibre, my speed has always been good. Today the speed dropped to only 1.60 Mbps and max I have seen today us only 3 Mbps. Upload does not seem to be effected. Ping is very high on tests 500 ms.
Cannot use Internet as its just to slow
I have reset and Rebooted the BT modem. Rebooted router. I use my own router but tried another router and that was the same.
Run out of ideas can you check your end or any issues in my area.
My details are all added in my profile.
Using another Internet to post as my home Internet is unusable
Thank you
on 16-03-2023 12:48 PM
Hi bearback,
If you'd like us to book the engineer visit can you confirm:
on 16-03-2023 12:44 PM
Yes please arrange for an engineer as there has been no improvement.
I am available any time any day so please book the earliest available appointment.
Thank you
on 16-03-2023 10:57 AM
Hi bearback,
I can arrange an engineer visit. if you'd like me to do this please let me know and I'll confirm some details with you
on 16-03-2023 09:15 AM
Not even usable now having to use mobile. 0.5 download and 1 upload. Ping and jitter back to being really high. No noise on phone. Done all the reboots and turning off 30 mins makes no difference.
Still showing on connection as my fault fixed and closed but its not. Can the engineer's be notified that I still have an issue or do I have to go through chat again.
on 16-03-2023 08:44 AM
Hi bearback,
Line test is still showing the outage as Open and not showing any other faults. Sync speed is still 160Mbps. Do you have any problems with your telephone service? Is there any noise on the line?
on 16-03-2023 06:52 AM
Contacted technical support through chat, on this occasion they were helpful finding the fault in the area and reporting and adding notes to my account. Also receiving text updates on the status of the fault.
all though the connection test indicates the fault is fixed the speed upload and download is slowly dropping. Seems all over the place and currently down to 30 down and 5 upload.
The report of a fault that has been closed needs to be re opened as it’s not fixed.
on 15-03-2023 04:08 PM
No still the same, not even reaching 1Mbps. Very high ping and jitter.
If you cannot do anything your end, can you send engineer.
on 15-03-2023 02:48 PM
No problem, please let us know how you get on
on 15-03-2023 02:41 PM
Yes tried leaving it off for over 30 mins but still no difference.
Will give it another try though.
Thanks for your reply
on 15-03-2023 02:36 PM
Hi bearback,
I'm sorry to hear that you're experiencing problems with your service. Line test is passing and sync speed looks good however there is an outage showing on your exchange. When you switched the modem off did you leave it off for 30 minutes, if not then could you give this a try and let us know how you get on
