Smart products won't connect to the internet anymore
GHallas
Message 5 of 5
I've got some meross plugs and magic home lights. Up until a few days ago everything worked fine but now when I try to connect my devices through my phone they won't find the WiFi. It just doesn't show up on the list. My phone, computer, iPad, TV are all working fine, it's the smart devices that won't link .
The meross app suggests allowing the mac address but I can't find anywhere in the router settings that does that.
Please help!!
4 REPLIES 4
MikeS86
Message 1 of 5
I have the Sagemcom fast 6454 router which has a land line phone socket. I am on Fibre150 + VOIP . as my router is in an upstairs room I bought Ptp-Link extenders which you can get from Argos or Currys price range from £29.99 -£49.99 { check for the speed you want}
Easy to install just plug in and go.  I now have my Smart TV and a laptop down stairs wired direct from the router to the devices via the house mains wireing .  no need for intermitt WiFi ( laptop now running at 149mbs )
Hope this helps,
MikeS 86
MikeS86
Message 2 of 5
OK then you will need to check for WiFi interference, as this will also check the health of your 2.4GHz band. This type of interference may have suddenly occurred (it can change by the minute anyway). Slow speed, intermittent dropouts, breaks in the signal or no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
Message 3 of 5
It is a sagemcom. FAST 5364-3. T8
Our devices seem to connect to 5Ghz. I can't tell if anything is successfully connecting to 2.4. I dont think so but I don't know how to check for certain
Message 4 of 5
Which make/model of router do you have? Can anything else (e.g. PC or phone etc) connect to the 2.4GHz band?
