Speed to device poor and WiFi intermittent
CarletonG
Message 9 of 9
Please help!
Since switching to TalkTalk Fibre approx 4 weeks ago, we have had poor WiFi connection. Having performed a number of speed tests, it seems our speed to the router is excellent, however the speed to devices is measured as far below this.
Ive read numerous posts but I’m left feeling even more confused. I’m studying for a masters degree so desperately need reliable internet.
Thanks in advance clever people.
8 REPLIES 8
Message 1 of 9
Hi Keith,  I shall send screenshots via PM shortly
Message 2 of 9
Thanks for that @Karl-TalkTalk@CarletonG I have just sent you a PM.
Message 3 of 9
Hi @KeithFrench
PM's are now enabled for @CarletonG
Message 4 of 9
HI @CarletonG
You currently do not have PMs enabled. I will ask TalkTalk to enable them for you.
Message 5 of 9
That is fine, you have the Huawei DG8041W Wi-Fi Hub.
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots that I have requested in my guide (no photos please they can be difficult to read as text can get out of focus when zoomed), from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this just puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so as I can find it easily.
Message 6 of 9
Hi Keith,
I checked and it’s the new black Huawai one. (Not sure if that’s the correct spelling)
CarletonG
Message 7 of 9
Hi Keith
We had no issues prior to the switch. I’ve tried the usual disconnecting everything, ensuring the router is in the best position etc.
It’s the new black WiFi router (currently advertised as the upgrade). I’ll have to check tomorrow for the model number. Thanks
Message 8 of 9
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
