Broadband connection dropping in and out for the past 3 months, end up hotspotting off my phone
Jpandjamo
Message 19 of 19
When I first joined talk talk, connection and speeds were reasonable,
however in the past few months the connection has been awful,
talk talk have tested the line and found no issues.
I am an online coach so a lot of my work is web based, I use zoom and loom as well as other programs, having poor internet speed and connection is having a serious impact on my ability to carry out my work effectively!
18 REPLIES 18
Message 1 of 19
I've sent you a PM to confirm some info so we can book an engineer.
Message 2 of 19
May as well book an engineer, it’s just done it 3 times whilst trying to watch Disney plus.
went to Amber flashing then to white and amber flashing, back to white. Then did it all again 3 times
Message 3 of 19
Hi Jpandjamo
Yes no problem. Just post here to let us know how you get on and if needed then we will book the engineer for you.
Message 4 of 19
Yeah fair enough,
shall we monitor it over this coming week and if continues book an engineer in?
I will say I haven’t noticed it AS much with the new router but it did happen still.
Message 5 of 19
Hi Jpandjamo
If you have tested with 2 different routers, cables and filters at the test socket and the connection is still dropping then the next step will be an Openreach engineer visit to the property.
Message 6 of 19
Both, we have tv and computer hardwired but it can drop out on both, but guess we notice it more on mobile devices.
Message 7 of 19
Hi Jpandjamo
I'm just checking if the re connections I can see are when the router has been rebooted.
Is the connection dropping when connected wired or only affecting the wireless connection?
Message 8 of 19
Yes have reset router, we’ve now installed the new Router and the internet was out the other evening around midnight for some time .
just getting annoying now to be honest, as I do a lot of work mostly online and my partner she works from home full time so everytime it does drop out it becomes a huge inconvenience
Message 9 of 19
Hi Jpandjamo
I can see a couple of re connections on the line. When the connection dropped did you reboot the router?
Skynet_TX
Message 10 of 19
Hi @Jpandjamo,
Is the replacement router the Huawei (front of router would be all black) rather than the Sagemcom (which has a bronze colour behind the holes on the front). Is the LED changing to Amber, then Amber / White when you are losing connection, or does it stay white ?
The staff here will be back on 29th to help further.
Message 11 of 19
Hi Chris,
thanks for sending the router out, we have connected up the new router, no change in all honesty, still drops out at random times, as we speak we have no internet, as I’ve had to tether from my phone for bt sport currently and laptop also says no internet on the wifi
Message 12 of 19
Hi Jpandjamo,
I've ordered the router, it should be with you within a couple of days but please allow up to 5 working days for delivery
Message 13 of 19
Hi Michelle,
yes that would be brilliant if possible!
sometimes it flashes Amber when it’s playing up, but also other times we have the white light on still when it’s playing up too!
Anonymous User
Message 14 of 19
Ok thanks for confirming. When the connection drops do any lights change on the router? Would you like us to send a Huawei Wifi Hub for testing purposes to rule this out? We would also send a router returns bag so that one of the routers can be returned.
Jpandjamo
Message 15 of 19
It’s both when on WiFi or when using an Ethernet cable. It just completely disappears. Leaving the only option to use our mobile hotspots from our phones. Both my partner and I work from home even when it’s not pandemic times. The issue is becoming more and more frequent.
Anonymous User
Message 16 of 19
I'm sorry to hear this. The line test is clear and the sync speed looks ok. Can I just confirm, are you connected wired or wireless when the speeds are low?
Message 17 of 19
I’d already spoken to them and they have tested the line and all good according to them, but using the internet here and my partner working from home full time, we’re obviously well aware that it isn’t ok 😬
Skynet_TX
Message 18 of 19
Hi @Jpandjamo,
It would be worth going to the Service Centre to run a connection test on your line around the time you are having problems, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
Anonymous User
