Talk Talk hub WiFi won't enable
Shilo
Message 8 of 8
Hi I can't get my hub to enable WiFi ,  even when I log into the router and try to enable WiFi it just keeps showing disabled. Can you help please thanks
7 REPLIES 7
Message 1 of 8
Thank you Debbie for your help much appreciated and Happy New Year 😁
Message 2 of 8
Hi Shilo
Shilo
Message 3 of 8
Thank you Skynet  ...a new router looks like the best solution
Skynet_TX
Message 4 of 8
Hi @Shilo,
If a factory reset doesn't fix it then the router is probably faulty, some of the staff here should be back tomorrow to help further, they will probably suggest that they send you a replacement router.
Message 5 of 8
Yes Debbie ..I tried the factory reset and still the same result ...not able to enable WiFi
Shilo
Message 6 of 8
Message 7 of 8
Hi Shilo
Have you also tried factory resetting the router using the pin hole reset for ten seconds?
Anonymous User
