Speeds
monster33
Message 5 of 5
I am only getting half the speed I am paying for.
4 REPLIES 4
Message 1 of 5
How are you getting on?
Message 2 of 5
If the devices connected by WiFi are the only slow ones, then it is likely to be WiFi interference.
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364/5464 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
monster33
Message 3 of 5
Hi Keith, sorry for the delay in replying.
To answer your questions:
(1) Talktalk fast5364-3.T8
(2 Fibre35.
(3)Between 6 - 8.
(4) TV is wired and OK
Two laptops, wifi, speeds as above.
Hope this is the correct info.
Message 4 of 5
2. What package are you on?
3. What is the speed shown by the router when you log into it? A different approach is required if full fibre.
4. If you have any wired connections, are they affected in the same way as wireless ones?
