Static Routes on LAN interface wont save
owensy
Message 10 of 10
Exact same problem that has been raised numerous times it seems and no fix yet so not sure what the point in raising a new topic is...
But anyway, go to static route page on the routers admin page, add a static route for:
192.168.2.0/24 to use gateway 192.168.1.97 on LAN interface, click the + sign to add it to the table and then click apply. You get a message to say the data was successfully saved but my entry has vanished from the static route table.
Im running firmware version SG4K10002828t.
9 REPLIES 9
Message 1 of 10
I'm glad to hear this and thanks for confirming 🙂
owensy
Message 2 of 10
Thanks so much, that fixed it for me
Message 3 of 10
Hi owensy
Thank you 🙂
Your firmware has now been updated.
owensy
Message 4 of 10
Hi Michelle
Any time this morning would be great, im out the house until this afternoon.
Message 5 of 10
I'm sorry for the delay. The firmware can take up to 30 minutes to update and you won't be able to reboot the router when this is upgrading. When would be the best time today for us to update the firmware for you?
owensy
Message 6 of 10
Thanks Michelle and Keith
Community profile has been updated.
Is V130 being rolled out currently or still in testing/development do you know?
Message 7 of 10
  • Name
  • Telephone number
  • Alternative contact number
Message 8 of 10
You need V130 for that to be fixed.
Message 9 of 10
Thank you. @KeithFrench - Would you be able to offer any advice please?
