TalkTalk Nameservers Not Updating -This is a serious problem TalkTalk.
freecycleuser
Message 2 of 2
I have a domain skyflash.uk which TalkTalk nameservers, and ONLY TalkTalk nameservers, are NOT updating AT ALL - more than 4 weeks after the IP changed.
I have seen several other posts with the same problem.
I can understand (though think in 2022 it's unjustified) that it might take a few hours, or even a day or two, but 4 weeks is totally unacceptable.
Yes, I know I can use other nameservers. The point is, all TalkTalk customers using DHCP will be using TalkTalk servers and won't see the correct IP.
What is TalkTalk doing about this "known" problem.
1 REPLY 1
Gondola
Message 1 of 2
Hi freecycleuser
You should get in touch with your domain host provider. The domain name has not been fully propagated through the DNS system or the host server is not updated. This is not a TalkTalk issue.
