TalkTalk Wi-fi Hub Band 1 2.4 GHz is not working
EagleAlex
Message 13 of 13
Hi All,
On my TalkTalk Wi-Fi Hub (version SG4K10002816t) i am not longer able to use Band 1 (2.4 GHz).
The Talktalk Wi-fi router is showing that the 2.4 Ghz Band status is "disabled", even though the usage of the 2.4 GHz  band is enabled.
I have attached the output of the router webpage
http://192.168.1.1/0.1/gui/#/simple/wifi
I had a call with technical support team for more than half an hour.
But they were not able to fix the problem.
Can i have the Wi-fi Hub replaced?
12 REPLIES 12
Message 1 of 13
Hi James,
Please can you create your own topic and we can look into this further for you.
JamesC1981
Message 2 of 13
Hi Ive just found I am having this problem too
Message 3 of 13
Could you check your email junk and spam folders to see if the email has ended up there by mistake
Message 4 of 13
Hi @Chris-TalkTalk
No i have not received the netflix token
Message 5 of 13
Hi EagleAlex,
Glad to hear it's working now
The Amazon code will be emailed to you within 37 days of going live
Have you received you Netflix token?
Message 6 of 13
Hi @Debbie-TalkTalk
Thanks for the help.
I got the new Wi-Fi Hub and the issue is fixed.
Please let train your techincal team, so that no other customer will have a bad experience as myself.
@Skynet_TX  Thanks for the quick response.
@Debbie-TalkTalk
During my recent talktalk broadband plan renewal, i had opted for Annual payment with the Amazon Pack and Netflix membership package.
I havn't received any details on
1. how to activate my netflix package
2. how to redeem the Amazon pack
Can you please look into it?
Message 7 of 13
Hi EagleAlex
Sorry for the delay.
Skynet_TX
Message 8 of 13
Hi @EagleAlex,
You are much better off coming here to the community for support. As you have tried a factory reset the support team here will likely suggest that they send you a replacement router, they should hopefully be able to respond tomorrow.
Message 9 of 13
Hi @Debbie-TalkTalk
Yes I have tried resetting the Wi-Fi hub multiple (atleast 5) times, still the 2.4 Ghz is disbled.
Can I have replacement of my Wi-Fi Hub?
Message 10 of 13
Hi @Skynet_TX
I cannot talk or chat with TalkTalk technical team. I have had enough from them. Its been a horrible experience.
I called TalkTalk contact number. the technical team didn't even knew about 2.4 GHz (Band 1) of the Wi-Fi router.
I chatted with TalkTalk online chat no use. I spend 3 hours chatting and at the end they just stopped the chat.
Message 11 of 13
Hi EagleAlex
Have you factory reset the router using the pin hole reset for ten seconds?
Skynet_TX
Message 12 of 13
Hi @EagleAlex,
Have you tried doing a factory reset by holding in the reset switch on the back of the router for over 10 seconds. If it still remains disabled after that then it is likely your router has developed a fault. The support team here would be able to arrange a replacement for you when they are back after the holidays.
For one of the TalkTalk Support Team on this community to be able to look into this you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk Support Team on this community can see your profile details).
