on 15-09-2022 12:18 PM
I work from home and connect to my office VPN via Cisco AnyConnect. This has worked fine up to now but suddenly I keep getting disconnected and unable to reconnect.
My office IT team have investigated and assure me that it is not a technical issue with my equipment or their network but that for some reason TalkTalk is disconnecting me from Cisco AnyConnect. This has been proven if I use my mobile phone as a hotspot and it connects fine so obviously my TalkTalk internet that is the issue but everything else appears to work.
Please advise how this can be resolved as I need a reliable connection with my office.
on 19-09-2022 08:14 AM
Thanks for confirming.
on 17-09-2022 09:57 AM
This appears to now be resolved. I spoke to TalkTalk and they advised me to press the reset button on the back of the router for 30 seconds (not just turn off at the wall which I had already tried). When it finally came back on (took a few minutes so don’t panic if you try it) the problem seems to have been resolved and I can reconnect to my office VPN. I was using it all day yesterday with no issues so fingers crossed it is fixed for good.
just thought I’d post the update in case anyone else having the same problem.
