Unreliable Wi-Fi since latest Wi-Fi hub firmware update
gghopkins
Message 39 of 39
since the last Wi-Fi hub update (maybe in November 2023) the Wi-Fi signal drops out completely quite frequently. Is there another update that can be sent to my hub to fix this?
thanks,
Graham
38 REPLIES 38
Message 1 of 39
Hi Graham
I'm so glad to hear this 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Message 2 of 39
Yes thank you Debbie. So far, so good.
Message 3 of 39
Hi Graham
Has everything been working ok since your last post?
Message 4 of 39
Good Morning Graham
I've checked the sync speed this morning and the line is in sync at 74.5mb.
How's the connection been for you?
Message 5 of 39
Hi Graham
Ahh great 🙂
I will check the connection stats again tomorrow morning.
Message 6 of 39
Yes, definitely.
Message 7 of 39
Hi Graham
The sync speed has increased already?
Message 8 of 39
yes, no problem. I can see the sync speed is up to 78 already!
Message 9 of 39
Hi Graham
Would it be ok to leave the router at the test socket for at least 48hrs without rebooting? (to see if DLM starts to increase the speed)
Message 10 of 39
Hi Debbie,
Yes, it’s been around 27-28 for 3 days now. It’s never been below 70 before though, which is strange.
I have not plugged in the router to the test socket. I can try that if it will help.
Thanks,
Graham
Message 11 of 39
Hi Graham
I've checked the sync speed again this morning and the sync speed is still at 27mb.
Did you connect the router at the test socket?
Message 12 of 39
Hi Graham
I've checked and the WIFI optimisation is still showing switched off.
Message 13 of 39
Hi Graham
There are re connections on the line and this can affect the sync speed.
Is the new router connected at the test socket? Would it be ok to leave the router at the test socket for at least 48hrs without rebooting? (to see if DLM starts to increase the speed)
Message 14 of 39
Ok. The sync speed is normally 72. What could have happened for it to drop so much?
Message 15 of 39
Hi Graham
The sync speed is currently 27mb so the throughput speed is always slightly less than the sync speed.
Message 16 of 39
the speed is still around 25mbps on Wi-Fi, right next to the router.
Message 17 of 39
Hi Graham
Apologies for this. I will check this again tomorrow morning to make sure that the optimisation is still showing switched off.
Message 18 of 39
Thank you Debbie.
yes, it was reset, but your colleague Chris said he turned off optimisation after that reset.
Never mind, hopefully it’s all fixed now.
Message 19 of 39
Hi Graham
Apologies, it appears that the WIFI optimisation was switched back on. Was the router recently reset?
I have now switched the WIFI optimisation off again.
Message 20 of 39
speed still not great - 25mbps. Can you check optimisation is off?
