VPN Connection not working #2
TengahMR
Message 23 of 23
***Posting this again as no reply to original post***
VPN's seem to be an issue with talktalk having read other posts on the subject recently on these forums. Mine no longer works and I cannot connect to the office when working at home. I've had my IT dept look into it and they've said the following:
"L2TP vpn is no longer working from hope but does from any other network connection, and can the please unblock vpns so you can work".
Could you help me please?
Don't panic
22 REPLIES 22
Message 1 of 23
I'm glad to hear this and thanks for confirming 🙂
TengahMR
Message 2 of 23
That has solved the issue. Many thanks.
Don't panic
Message 3 of 23
Hi TengahMR
Thank you 🙂
The firmware has now been updated, please can you retest and let us know how the connection compares.
TengahMR
Message 4 of 23
Private message sent
Don't panic
Message 5 of 23
Hi TengahMR
I'm really sorry but I still can't connect to your router. Did you make a note of the serial number to send me in a Private Message?
TengahMR
Message 6 of 23
Router#2 was disconnected this morning ready for you to update the firmware on the TT router. Thanks in advance.
Don't panic
Message 7 of 23
TengahMR
Message 8 of 23
Hi Debbie, I will let you know once router#2 has been disconnected.
Don't panic
Message 9 of 23
Hi TengahMR
Ahh ok. Please can you just have the 1 router connected while I check the firmware?
TengahMR
Message 10 of 23
Hi Debbie,
Ah yes, we have another router from the TT router which provides connectivity to another part of the house where the TT router doesn't reach. This is connected via ethernet to the TT router. Do you want me to disconnect this?
I will send you a private message with the router serial number when I am home this evening.
Have you switched TR069 off in the router settings? I don't even know what this means.
Don't panic
Message 11 of 23
Hi TengahMR
You don't have 2 routers connected?
Could you send me a Private Message with the serial number from the back of the router?
TengahMR
Message 12 of 23
Hi Debbie, the TT router is connected to the TV, Hive and the XBOX via ethernet cables. Do these need to be removed in order for you to connect to it?
Don't panic
Message 13 of 23
Hi TengahMR
Apologies, I'm still unable to connect to your router.
Do you have anything else connected except the TT router?
TengahMR
Message 14 of 23
Good morning. Router was reset last night as requested.
Don't panic
Message 15 of 23
Hi TengahMR
No this shouldn't affect it. Please post back here to let us know once the router has been reset.
Thanks again.
TengahMR
Message 16 of 23
Hi Debbie, will do.
We recently had fibre installed. No idea if that has anything to do with not being able to connect to the router?
Many thanks.
Don't panic
Message 17 of 23
Hi TengahMR
Thank you. Please can you also leave the router switched on overnight, If I'm not online when you get home then I can check and update the firmware first thing tomorrow morning.
TengahMR
Message 18 of 23
Thanks for replying Debbie. I'm not able to do that until this evening. I will do a factory reset when I return home and then let you know on here once it has been done.
Don't panic
Message 19 of 23
Hi TengahMR
Thank you. I can't connect to your router.
Could you factory reset the router for me using the pin hole reset for ten seconds?
TengahMR
Message 20 of 23
Hi there, thanks for replying. I've added my landline telephone number now to my profile so you can take a look at this for me.
I have the router that talk talk sent to me.
Don't panic
