Waiting for broadband to go live
Message 4 of 4
Hi, I was told my broadband would go live today I have the sold blue light on the box and shows up on available networks but when I enter password it says no internet connection
3 REPLIES 3
Message 1 of 4
  • TalkTalk Telephone number
Skynet_TX
Message 2 of 4
Hi @cameronfreamechurchill1,
A solid white (or some people see it as blue) LED would generally indicate that the router is connected successfully.
Do you have both wired and wireless devices, if so are you experiencing this issue on both ?
I assume when you say you are entering a password you are referring to the Wi-Fi password to connect your wireless devices to the router ?, if this is the case, then do the device successfully connect to the Wi-Fi, but then just can't access the internet.
You could try a factory reset of the router by holding in the reset switch on the back for over 10 seconds, just to see if that helps.
The Support Team on this community probably won't be around until Monday now, so you may get faster support by using the live chat or calling customer services on 0345 172 0088 over the weekend, however the Support Team here should respond to this topic early next week to help if you are still having issues.
@Divsec, Ooops, we were both typing our replies at the same time !
Divsec
Message 3 of 4
  • Hi @cameronfreamechurchill1 it can take up to midnight for things to go live. I suggest check tomorrow and reboot the router if there is no change. Please do et us know how you get on
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
