VPN STOPPED WORKING
FSantos
Message 6 of 6
Hi, My VPN connection to work has stopped working from 13thh January and I am get the error message  "Error 619 : A connection to the remote computer could not be established, so the port used for this connection was closed."
It was working OK from March 2020, . I have noted that a number of users appear to having a similar problem from Thursday 13 January.
The router which we have  (with no problem for about 2 years) is a TalkTalk WI-FI HUB FAST 5364-3. T8
Please can you let me know if there is a solution to this issue as I need to be able to work from home which I am unable to do at present.
Many thanks,
Fabio
5 REPLIES 5
Message 1 of 6
Hi Fabio
Sorry for the delay. The Huawei WIFI hub is on its way, please allow 24-48hrs for this to arrive.
FSantos
Message 2 of 6
Hi Debbie
Please I would like to have a new router (due many people have the same issue and a new router solved it)
Thank you
Fabio
Message 3 of 6
Hi Fabio
Apologies for this.
I can make a change to the firmware version or I can send you a different make and model of router for testing. Which would you prefer?
Skynet_TX
Message 4 of 6
If you go to http://192.168.1.1/ does the version at the bottom of the screen say SG4K100130 ?
Are you using the built in Windows 10/11 VPN, or some other 3rd party VPN software ?
If you have firmware SG4K100130 and you are using the built in Windows 10/11 VPN then that combination can sometimes cause problems. The staff here may be able to tweak some settings on your router, or may just suggest that they send you a router of a different type.
Gliwmaeden2
Message 5 of 6
Staff will not be back on here before Monday, @FSantos.
When they return, they will need to identify your account from your community forum profile details.
Please complete these by going via your avatar/name; settings; launch profile wizard.
Meanwhile, apart from help through the community, support on 03451 720088 is available on Saturday and Chat is available any day from 9am:
https://community.talktalk.co.uk/t5/Articles/Our-live-chat-team/ta-p/2230529
