VPN and Online Gaming Not Connecting
RobLewis2
Message 8 of 8
Hi, I have fibre broadband with the following router:
TalkTalk Wi-Fi Hub
version SG4K100130
Everything was working fine until night before last - appears that a new firmware was applied to the router, and since then I've been unable to connect to my work's VPN (timesout), also, son has had issues with online gaming.
Have restarted the router, checked DNS settings. I'm an IT Manager so reasonably comfortable making these changes and diagnosing such issues.
Feels like certain ports are being blocked, despite firewall rules.
Normal web browsing is ok (although I would say it's slightly slower than normal), also had Zoom connection drop outs yesterday morning which may or may not be linked.
Nothing else on the network has changed.
7 REPLIES 7
Message 1 of 8
Future firmware updates should work fine but you shouldn't automatically be updated to 130 again
Message 2 of 8
Thanks - seems to have worked. What happens about future firmware updates?
Message 3 of 8
OK, I've started the firmware update, it should complete in a few minutes
Message 4 of 8
Yes go for it.
Rob
Message 5 of 8
Message 6 of 8
Hi Chris - yes please.
Rob
Chris-TalkTalk
Message 7 of 8
Hi Rob,
We can try rolling your firmware back if you're experiencing problems, would you like me to do this?
