on 22-10-2025 04:35 PM
Since going on Fibre 500 I've been using VOIP by connecting my analogue phones to the internet via Talktalk's adapter. I now have a Gigaset A300IP base plus Gigaset S700 handset which are both VOIP enabled. However, I can't get registered with Talktalk's service. I've logged into the Gigaset base but the settings Talktalk have given me (from the Online Chat) don't correspond with the info required by the Base for configuration. Has anyone any experience of this?
on 23-10-2025 03:36 PM
Thank you so much @ferguson.
on 23-10-2025 03:35 PM
Hi @nambuso-TT
Only to contact the phone makers directly, as I suggested earlier. It is not in any sense that I can see a TalkTalk issue.
on 23-10-2025 03:30 PM
@ferguson any suggestion on this?
on 23-10-2025 03:26 PM
Since I last posted the system using my old base does not provide all the features listed on the handset. I still don't understand how I can plug in the old base with no configuration and VOIP works, but the n300ip base has to be configured.
on 23-10-2025 12:18 PM
Okay no worries, thank you very much for letting us know. Should you require any assistance, please do not hesitate to contact us. Thank you very much for contacting TalkTalk. Have yourself a lovely day.
on 23-10-2025 12:16 PM
I've connected my old Gigaset base to the adapter as before but using the new Gigaset handsets (S700) and it works. So I'll have to leave it like that.
on 23-10-2025 08:05 AM
22-10-2025 10:07 PM - edited 22-10-2025 10:10 PM
Me neither. Have you tried reaching out to Gigaset directly? I have looked for that model on their website, but can't find it.
on 22-10-2025 09:45 PM
Three lights showing on the adapter. My analogue phone system is a Gigaset and when the Fibre 500 was installed the Gigaset base was simply plugged into the adapter and the adapter was connected to the Eero. I can't understand why I can't simply plug in the new A300IP base in the same way without having to configure it with a variety of settings.
on 22-10-2025 08:54 PM
Hmm, not sure what you mean by VoIP "enabled," any handset should just plug and go. What are the lights on the Grandstream showing?
on 22-10-2025 07:31 PM
I did think that having a VOIP enabled base meant I didn't have to use the adapter. However I've connected the phone from Base to adapter and ethernet from adapter to Eero, but the handset shows "No LAN".
on 22-10-2025 04:47 PM
on 22-10-2025 04:43 PM
Have you connected the new base unit to your existing VoIP adapter?
on 22-10-2025 04:42 PM
Hi there @harbledown, please contact our full fibre team using the details blow and they will be able to assist you. Thanks
03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
https://community.talktalk.co.uk/t5/FutureFibre/bd-p/FutureFibre
