Home Phone
Setting Up VOIP
harbledown
Message 15 of 15
Since going on Fibre 500 I've been using VOIP by connecting my analogue phones to the internet via Talktalk's adapter. I now have a Gigaset A300IP base plus Gigaset S700 handset which are both VOIP enabled. However, I can't get registered with Talktalk's service. I've logged into the Gigaset base but the settings Talktalk have given me (from the Online Chat) don't correspond with the info required by the Base for configuration. Has anyone any experience of this?
14 REPLIES 14
Message 1 of 15
Thank you so much @ferguson.
Message 2 of 15
Hi @nambuso-TT
Only to contact the phone makers directly, as I suggested earlier. It is not in any sense that I can see a TalkTalk issue.
Message 3 of 15
@ferguson any suggestion on this?
Message 4 of 15
Since I last posted the system using my old base does not provide all the features listed on the handset. I still don't understand how I can plug in the old base with no configuration and VOIP works, but the n300ip base has to be configured.
Message 5 of 15
Okay no worries, thank you very much for letting us know. Should you require any assistance, please do not hesitate to contact us. Thank you very much for contacting TalkTalk. Have yourself a lovely day.
Message 6 of 15
I've connected my old Gigaset base to the adapter as before but using the new Gigaset handsets (S700) and it works. So I'll have to leave it like that.
Message 7 of 15
Hi there
@harbledown please confirm with feedback so that we can be able to advise further.
Message 8 of 15
Me neither. Have you tried reaching out to Gigaset directly? I have looked for that model on their website, but can't find it.
harbledown
Message 9 of 15
Three lights showing on the adapter. My analogue phone system is a Gigaset and when the Fibre 500 was installed the Gigaset base was simply plugged into the adapter and the adapter was connected to the Eero. I can't understand why I can't simply plug in the new A300IP base in the same way without having to configure it with a variety of settings.
Message 10 of 15
Hmm, not sure what you mean by VoIP "enabled," any handset should just plug and go. What are the lights on the Grandstream showing?
harbledown
Message 11 of 15
I did think that having a VOIP enabled base meant I didn't have to use the adapter.  However I've connected the phone from Base to adapter and ethernet from adapter to Eero, but the handset shows "No LAN".
siphosethu-TT
Message 12 of 15
You can also allow @ferguson to help, he's more skilled on these types of issues. Thanks for the support by the way @ferguson, it doesn't go unnoticed. Thanks
Message 13 of 15
Have you connected the new base unit to your existing VoIP adapter?
siphosethu-TT
Message 14 of 15
Hi there @harbledown, please contact our full fibre team using the details blow and they will be able to assist you. Thanks
03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
https://community.talktalk.co.uk/t5/FutureFibre/bd-p/FutureFibre
