VPN has stopped working
ClareM12
Message 9 of 9
I can see many messages on this forum with people having the same problem.  I have a windows vpn configured to work with a customer which has worked fine for years.  I came to do some work for them today and it has stopped working.  I know it is it the router because I can connect my laptop to my mobile in hotspot mode to bypass the router and the vpn works fine.
From the other entries on this forum there does not appear to be anything I can do until somebody at TalkTalk gives me a new firmware version or sends me a new rourter.  My router is showing as hardware version = FAST5364 3.00 and software version = SG4K100136.
Please help.
Clare
8 REPLIES 8
Message 1 of 9
Hi @myerl
Please can you create a new topic on the Community, we can then take a look at this for you.
Message 2 of 9
I am having the same VPN problem with my TalkTalk router in that VPN no longer works since 5 May.
The router is showing as hardware version = FAST5364 3.00 and software version = SG4K100136.
Please can you update the firmware to fix the problem as TalkTalk have sent me a replacement router, but the issue is not resolved, hence Firmware update seems to be the only solution.
Many thanks for your help
Message 3 of 9
I am having the same problem with my TalkTalk router in that VPN no longer works since 5 May.
Are you able to upgrade my router with the correct Firewall
Myer
Message 4 of 9
Hi Clare
I'm so glad to hear this 🙂
Thanks for letting us know.
ClareM12
Message 5 of 9
That has fixed the problem.   Thank you for doing the update so quickly.
Message 6 of 9
Hi Clare
Thanks for reply 🙂
This has now been updated, please let us know how the connection compares.
ClareM12
Message 7 of 9
Yes, please go ahead and make the change.
Thanks,
Clare
Message 8 of 9
Hi Clare
Apologies for this.
Will it be ok if I make a change to your router firmware now?
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes to update.
