VPN not working
jenwoo10
Message 13 of 13
After successfully using my VPN during covid it has now stopped working and I can no longer connect. Last time I used it was around May time.
Has there been any changes to the router that would cause my broadband to block the connection?
Our IT department have tried every possible workaround, but it is still not working and have suggesting it may be something to do with my broadband provider.
Can anyone help?
Thank you in advance
12 REPLIES 12
Message 1 of 13
I'm really glad to hear this and thanks for confirming.
jenwoo10
Message 2 of 13
Thank you, yes it is all working fine now. Thank you for your help!
Message 3 of 13
Is everything now working ok?
Message 4 of 13
jenwoo10
Message 5 of 13
Thank you Chris, I will confirm in this topic that it is working once I have chance to check later today.
Message 6 of 13
Hi Lynda,
Can you please start your own topic and update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Lynda1781
Message 7 of 13
Hi, I am also having this issue with my VPN, I have been on live chat to TALKTALK twice but have not yet had this resolved.
Could you please help me with this please?
Lynda1781
Message 8 of 13
Hello,  I am having the same issue and can no longer connect to my VPN. I have been on the phone to TALK TALK twice now with no help resolving this. Can anyone help me out as it is causing me real issues now with working from home.
Message 9 of 13
Firmware update is in progress, this should complete within 15 minutes 🙂
Message 10 of 13
OK, I'll update your firmware now 🙂
jenwoo10
Message 11 of 13
Hi Debbie, thank you for the reply.
My router is switched on currently but I am not at home, so if you can do it without me being there then happy for you to do this now?
Thank you
Message 12 of 13
Hi jenwoo10
Apologies for this.
I will need to make a change to your router firmware, when would be the best time to do this?
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes to update.
