on 03-06-2022 03:39 PM
About couple of weeks, a go my work VPN stoped working. My company IT have checked all they can over there end and mine. I can connect using a different network, been in touch with TalkTalk support twice over this case with no success. Please can anyone help?
Thanks Matt
on 07-06-2022 08:49 AM
Hi Matt
I've just sent you a Private Message 🙂
on 07-06-2022 06:43 AM
Hi Matt
I'm so glad to hear that this is working 🙂
Thank you for your kind words and I'm sorry for the issues you experienced when reporting this issue.
If you do experience any further issues then please let us know here on the Community.
on 06-06-2022 06:00 PM
Debbie, you are a STAR. You can`t imagine how much of a help this is for me.
If I can rate your help somehow please point me in the right direction.
Thank you again
Matt
on 06-06-2022 07:58 AM
Hi Matt
Yes of course, please let us know how you get on.
Debbie 🙂
on 06-06-2022 07:57 AM
Hi Debbie.
I`m at work till the afternoon, will reset and test this afternoon and feed back if that's ok?
Thanks Matt
on 06-06-2022 07:53 AM
Hi Matt
All updated, please can you retest?
on 06-06-2022 07:47 AM
Hi Matt
Thank you 🙂 I will start the update now and I will post back as soon as this has been completed.
on 06-06-2022 07:46 AM
Hi Debbie.
Yes please , that would be great.
on 06-06-2022 07:44 AM
Hi MattCyg
Will it be ok if I start the FW update in the next 15 minutes?
We advise to leave the router switched on without being rebooted whilst we update the firmware.
on 03-06-2022 07:24 PM
Hi @MattCyg,
Firmware SG4K100136 is quite new and has only recently been pushed out to the Sagemcom router, several customers have found that is has caused issues with their VPN connection, so it is likely this is what has happened for you too. The support team here will be back on Monday and will likely be able to fix this by changing the firmware version on your router.
For one of the TalkTalk Support Team on this community to be able to look into this you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk Support Team on this community can see your profile details).
on 03-06-2022 04:05 PM
Hi Keith yes router is Sagemcom but not sure where to find firmware version. I think its SG4K100136.
on 03-06-2022 03:40 PM
Are you using the Sagemcom router with firmware V136 on it?
