Valid characters for wifi password on a DG8401W
webbew01
Message 3 of 3
I use Norton 360 which tells me that my wifi password is too weak, my current password is 12 characters mixed case including numbers, I tried a # symbol which the router rejected as invalid so I'm looking for other characters which the router will accept.  There doesn't seem to be any documentation on this or help on the router.  Hopefully, someone can supply a list of valid characters otherwise it's either time to buy a different router which does support some special characters and comes with some documentation or change my AV software to one which isn't so picky about security.
Message 1 of 3
Hi @webbew01
I can send you a replacement router, are you happy for me to arrange this?
Gliwmaeden2
Message 2 of 3
That router hasn't had firmware updates for quite some time, @webbew01. It should simply be swapped out for the latest Talktalk Sagemcom.
Staff support will follow up after the weekend.
