WIFI OPTIMISATION
Chris1012
Message 134 of 134
I recently switched to Talktalk broadband and I'm having issues with WIFI optimisation and channel hopping causing certain devices to disconnect from the WIFI network. From reading these pages I understand that a Talktalk employee can disable this feature on my router? Please can this be actioned?
133 REPLIES 133
Message 121 of 134
Hi Debbie,
Looking at the log I've not had any more of the 'WiFi security settings have been successfully saved' entries (and associated disconnects/reconnects) since you made the change on Friday morning. I've also been able to connect to the 3D printer with no problems. It's early days, but it's looking promising and fits with other reports that disabling wifi optimisation solves the connection issue. I'll let you know if the issue reappears.
Message 122 of 134
Hi Chris
How's the connection been since your last post?
Message 123 of 134
Hi Chris
No problem. You don't need to reboot the router, the changes have already taken affect.
Message 124 of 134
Hi Debbie,
Thank you for disabling the wifi optimisation, is there anything I need to do here, i.e. restart the router?
Message 125 of 134
Hi Chris1012
Ok, I've switched the WIFI optimisation off and I will feed this back to our Devices Team.
Please can you retest and let me know how you get on.
Thanks again.
Message 126 of 134
Hi Chris,
The issue has happened again this evening (18 April) at around 7pm. Checking the router log there are several entries for 'WiFi security settings have been successfully saved' at around 7pm, followed by devices disconnecting and reconnecting - none of these 'security settings' were instigated by me! I've looked through the community pages and there are several reports of this happening (two linked below), together with devices (printers) being unreachable. I see that in at least one of these cases you were involved. The solution in both of these cases seems to have been to disable the wifi optimisation, but you say this is not possible? Please could you investigate further since this seems to be a documented issue that causes devices to become unreachable on the network.
https://community.talktalk.co.uk/t5/Fibre/Wifi-security-settings-have-been-successfully-saved-droppi...
https://community.talktalk.co.uk/t5/Broadband/WiFi-security-settings-messages-and-devices-offline/td...
Message 127 of 134
Message 128 of 134
It happened a couple of times over the past week, but I couldn't give you dates and times. When it happens again I'll note the date/time and add to this post.
Message 129 of 134
Ok, thanks. If you could give a couple of dates and times when you experience the problem we could ask our Product team to take a look to see if there's anything that could be causing the problem
Message 130 of 134
Everything else appears to be fine, it's just the 3D printer that I can't connect to some of the time. I'm sure setting and fixing the wifi channel number would help, but if this is not possible in the router then a restart of the printer solves the issue.
Message 131 of 134
OK thanks, do your other device appear to be OK, is it just the 3D printer that you're experiencing problems with?
Message 132 of 134
Hi Chris,
The device is only a few feet away from the router. I had a similar issue with my previous ISP/router (SKY) and it was partly solved by setting the channel number in the router (it would still disconnect, but not as often). It's not a big issue since the device (a 3D printer) isn't used everyday and a restart makes it connect again to the wifi.
Chris-TalkTalk
Message 133 of 134
Hi Chris,
I'm sorry, we are unable to disable wifi optimisation at the moment. Approximately how far are the device experiencing the disconnections, from the router?
Anonymous User
