What WiFi
JohnTTTM
Message 5 of 5
How can I tell if my router is Wifi 6e compatible ?
or how can i tell what version is my router for example is it wifi 5 or wifi 6
Geoff Holland
4 REPLIES 4
Message 1 of 5
Hi JohnTTTM
Sorry for the delay.
It looks like you are using the Sagemcom WIFI hub. I don't believe this will be compatible for what you asked in your original post. None of our routers are wifi 6 - only the eero is wifi 6.
However I've just checked with the team and they didn't think that the mini PC needed to have wifi6.
Message 2 of 5
Hi JohnTTTM
Please can you add your name and TalkTalk landline number to your Community Profile, we can then check which router you have.
JohnTTTM
Message 3 of 5
I am thinking about buying a miniPC and it says WiFi 6E but i dont know if my router is compatible with WiFi 6E
Also I dont even know if my router is wifi 4 , wifi 5  or wifi 6 How can I find out ???. I have looked on the back of my router and it does not say .
All I can say is that it was supplied by TalkTalk about 2 years ago
Geoff Holland
Message 4 of 5
Hi John,
Which router do you have please? (make and model) Do you have an eero?
We’ve partnered with Amazon eero to bring you the best Wi-Fi experience, combining the latest Wi-Fi 6 tech with an easy-to-use app for connecting and managing your devices safely and securely.
