Wi Fi router reset
Allastair
Message 10 of 10
I have to reset my wi fi router (Huawei) nearly every day to stop devices running slow, and tv buffering. Its ok after a manual reset for a few hours.
9 REPLIES 9
Message 1 of 10
Hi Allastair
Thanks for your Private Message.
I'm glad to hear that the router has now arrived. Please let us know how the connection compares.
Anonymous User
Message 2 of 10
Morning Allastair,
Just checking in to see how you're getting on and if the router has arrived?
Message 3 of 10
Hi Allastair
I'm really sorry about this.
If you don't receive the router today then please let me know and I will order another one for you.
Message 4 of 10
Hi Michelle - still no news from Yodel. From past experience of them, I suspect the next message will be 'We're sorry, but we can't find your package'. Lets hope I'm proved wrong. I'll give them another chase tomorrow if there's no news. Best regards Alastair
Anonymous User
Message 5 of 10
Hi Allastair,
Has the router arrived?
Message 6 of 10
Hi Allastair
Message 7 of 10
Hi Michelle - that would be good - at the moment its very frustrating when the blue circle keeps appearing! Hopefully this will sort it. Regards Alastair
Anonymous User
Message 8 of 10
Hi Allastair,
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault and the sync speed looks consistent. Would you like us to send a replacement router for testing purposes to rule this out? We would also send a router returns bag so that one of the routers can be retutned.
Message 9 of 10
Have you done a speed test when you first reset and when you need to perform a reset? What speeds are you getting and what package are you on?
Continually resetting your router can actually have an adverse effect as line management will see each disconnect as a fault and reduce your speed to compensate.
Maybe try a few days without resetting to see if things improve.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
Anonymous User
