Ip address gives me USA adverts
on 18-02-2024 09:49 AM
Message 13 of 13
Hi, for some time now when attached to our home IP address all me searches adverts place us in the usa . This is the case with both pc and our phones. It's very annoying.
Labels:
- Labels:
Router
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
12 REPLIES 12
on 23-02-2024 10:12 AM
Message 1 of 13
Hi Poots,
How has your connection been over the last few days?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-02-2024 11:19 AM
Message 2 of 13
Hi Poots
Thank you. Please let us know how you get on.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-02-2024 11:06 AM
Message 3 of 13
Ok thank you I'll try that when home tonight. Is did try a reset but didn't leave it that long. Many thanks
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-02-2024 08:40 AM
Message 4 of 13
Good tip from Michelle and this may also assign a new public IP address to your router.
Here's some advice from Google on search results that indicates it's not just the public IP address that is used to determine your location but that previous activity and other connected devices may have an influence.
Gondola Community Star 2017-2024
Like below to appreciate my post . . . Mark as solved Accept as Solution
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-02-2024 08:14 AM
Message 5 of 13
Hi Poots,
Have you also tried powering down the router for a full 30 minutes as this will reset the current session?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-02-2024 07:12 AM
Message 6 of 13
Hi, thanks again for you reply. I'll do as you suggest but why does my wife's phone also have the same results and a laptop that doesn't get used much give the same results? . As I don't have a problem when on 5g this would suggest there's a problem with the internet at home? Am I missing something? Many thanks
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-02-2024 10:33 PM
Message 7 of 13
I certainly would expect you to get UK advertising etc. Make sure your browser time zone is set for the UK GMT and if necessary clear the browser cache and all cookies.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-02-2024 10:26 PM
Message 8 of 13
It gives approx location of Newcastle. It's UK so you would imagine I'd get UK results. I've turned off the VPN some time ago. It was the first thing I tried.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
18-02-2024 10:23 AM - edited 18-02-2024 10:24 AM
Message 9 of 13
Click on the above link and it'll give the public IP address.
I see that if you're using the UK mobile phone network you get UK search results. This does suggest that your home broadband public IP address is not registered in the UK as would be the case if you were using a VPN hosted overseas.
To allow websites to show the right content for your region, VPN by Google One will assign you an IP address based on your current region and you cannot pre-select a VPN host server. With other VPN's you can usually select the host server you wish to use.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-02-2024 10:15 AM
Message 10 of 13
If I want to search for say a coat the adverts are for American web sites . This goes for both mine and my wife's phone plus the pc . I've contacted Google and given them my IP address to check it out. Sorry I'm not too complete savvy.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-02-2024 10:12 AM
Message 11 of 13
Thanks for your reply .No I had Google one VPN but switched it off and as far as I know no other VPN in use. When away from home or using 5G the results are UK based.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-02-2024 09:56 AM
Message 12 of 13
What is your public IP address? Are you using a VPN as part of a standalone VPN service, a work from home connection, or VPN as part of an Internet Security package?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
